An assert has failed. If assert_dlg is set to 'Continue', execution will continue. Otherwise, the program asserts according to the method in assert_dlg.
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: "show tech" and "upload debug". System Restart may be required for continued operation.
Error
Assert Fail: file %p2%:%p3%: '%p1%' nasserts=%p4%
| Name | Type |
| p1 | String |
| p2 | String |
| p3 | sInt |
| p4 | uInt |
